Warning message
Access Point
Mar 13th, 2014
Is there a setting in the 520 switch that would not allow routers that are setup as access points from working when they are plugged into the switch. Tried 2 different brands that I have used multiple times while not going through a cisco switch.
One of them when plugged in instantly disables the port and the other the port stays active but you are not able to connect to the access port.
