Warning message
Cisco ASA remote access vpn permissions
Mar 14th, 2014
hi all ,
i  wan to ask a question in  remote acces vpn
actually i have asa with
---outside-------ASA------inside
i configured RAvpn with cisco cpn client
when i logged by vpn , i can access every hting in the inside lan
i just want to use an acl to put some restrictions
i confiigured acl on the outside interface that deny ips of vpn pool to reach somehting inside the network
but
its not working !!
i mean there is no match int he acl on the outside interface ???!!!
im wondering
does that i did is correct ?
does the vpn  users when they conneted to outside public ip interface are dealled as they are outside ?
or dealled as they are inside ??
and also , how set restricstions on the vpn users  connected  ???
regards
LA-Engineer Sun, 03/16/2014 - 18:16
I would use a vpn-filter on the group-policy to controller access for vpn users.  If you have the 'sysopt connection permit-vpn" invoked, VPN traffic will bypass your ACL applied on the 'outside' interface.
