Warning message
Installed MPLS VPN. Now what?
Mar 14th, 2014
Hi Experts,
After a few weeks of research and frustration, finally installed a working MPLS VPN between 3 sites. Configured 3 CE routers using static route. Default QoS on all location - which means no QoS configured.
My question is, just as the title says - Now what? I wanna know if there are other things that I should actively monitor?
Is MPLS VPN something that is install and practically forget? Or this this something that I should check on everyday?
I know that there's there's saying that - If ain't broke, don't fix it. But I am interested of those things that we can do to improve with what we have.
Hope to hear from you soon.
Thank you.
Jem
lthangli Tue, 08/05/2014 - 06:49
  • Cisco Employee,
Its been quite sometime now since this query is posted. Nevertheless, i would like to comment that once the MPLS VPN is operational, there is really nothing to monitor/check on daily basis.
As you rightly said "If ain't broke, don't fix it".
Lal.
santiago.jem Wed, 08/06/2014 - 08:43
Thanks for the reply Lal appreciate it and yes that's exactly what I did.  :D
