Warning message
Duplicate TCP SYN
Mar 14th, 2014
Support Community,
I've been trying to set up the following commands in my ASA5515 running ver. 9.125 for Duplicat TCP SYN Flood attacks. So I put in the default values that you find in the Cisco documentation but this didnt work for me to well. It slowed the internet down to a crawl and some pages like Cisco.com wouldnt even come up. Going to CNN about a quarter of the graphics would come up. I have an office of 25 people that Im trying to maintain a level of security for. I was wondering if you could direct me in the correct direction, or anybody out there that has enabled this for there network.
John W.
  1. Configuring the commands to help stop SYN Flood attack  or (DOS)
ciscoasa(config)#class-map tcp_syn
ciscoasa(config-cmap)#match port tcp eq 80
ciscoasa(config-cmap)#exit
ciscoasa(config)#policy-map tcpmap
ciscoasa(config-pmap)#class tcp_syn
ciscoasa(config-pmap-c)#set connection conn-max 100
ciscoasa(config-pmap-c)#set connection embryonic-conn-max 200
ciscoasa(config-pmap-c)#set connection per-client-embryonic-max 10
ciscoasa(config-pmap-c)#set connection per-client-max 10
ciscoasa(config-pmap-c)#set connection random-sequence-number enable
ciscoasa(config-pmap-c)#set connection timeout half-closed 0:0:30 embryonic 0:00:30 dcd 0:0:15 5 idle 1:0:0
ciscoasa(config-pmap-c)#set connection timeout tcp 1:0:0
ciscoasa(config-pmap-c)#exit
ciscoasa(config-pmap)#exit
ciscoasa(config)# service-policy tcpmap interface Internet_access
