Warning message
Jump Upgrade for CUCM from 7.1.5 to 9.1.2
Answered Question
In the very last procedure, the document mentioned that after upgraded to 9.1.2 on your VM, you need to rebuild virtual machines to  align disk partitions. To rebuild VM, you have to install another brand new 9.1.2 CUCM and backup the configuration from the one you just upgraded, then restore it. Just wondering that is there an easy way to fix the alignment issue on virtual machine?
Eric
Correct Answer by Jaime Valencia about 3 years 5 months ago
No, that's the reason why you need to do that final backup and restore.
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Fri, 03/14/2014 - 16:50
  • Cisco Employee,
  • Hall of Fame,
    2011
