Warning message
ISA500
Mar 15th, 2014
I'm trying to set remote VPN connection to my factory's netowrk using IPsec VPN, I followed IPsec VPN creation wizard with the following information:
Internal protected network: 192.168.1.*
ISA500 LAN IP: 192.168.1.3
ISA500 WAN IP: 192.168.75.3 (connected to ADSL router)
ISA500 gateway: 192.168.75.1 (ADSL router IP)
ADSL router internal IP: 192.168.75.1 (connected to ISA500)
ADSL router external IP: our public IP
IPsec information:
IKE authentication method: pre-shared key
Pool range for client LAN: 192.168.85.100 - 192.168.85.200
Zone access control: Permitted to all zones
Primary DNS: 192.168.1.12
No split tunnel or split DNS configured
Using Cisco VPN client from external netowrk, I can connect and authenticate successfully to the ISA500, so I'm VPN connected.
Client machine information:
OS: Windows 7
VPN IP: 192.168.85.100
Gateway: 192.168.85.1
DNS: 192.168.1.12
I can see from IPsec VPN status page that I'm connected, with the above network settings, however, I cannot connect to any host inside my network
range 192.168.1.*, I cannot even ping 192.168.85.1.
From IPsec VPN status page, Tx Bytes and Rx Bytes are always zero, meaning that no traffic is passing through the VPN tunnel as far as
I understand.
Please help me getting this to work as I'm in urgent need to have it running.
Thank you for your help
