Warning message
ASA Failover between three ASA
Answered Question
Mar 17th, 2014
I want to make this senario for failover like in attached picture,
for ASA-A its connected to deffrent ISP of ASA-B, and every ASA handle deffrent network, can i put another ASA with two context as standby for actives FW's
Thanks.
Correct Answer by Marvin Rhoads about 3 years 5 months ago
No - sorry that will not work.
"The two units in a failover configuration must:
Be in the same context mode (single or multiple)."
Source.
Overall Rating: 5 (1 ratings)
Correct Answer
Marvin Rhoads Mon, 03/17/2014 - 11:19
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 Firewalling, Network Management, VPN
Source.
Karsten Iwen Wed, 03/19/2014 - 00:48
  • Purple, 4500 points or more
    2017 Firewalling, VPN
As Marvin stated, it won't work as in your picture.
But if you don't need any features that are not available in multiple-context-mode, then you could configure Active/Active-failover between ASA-A and ASA-B with one context for the operation of ASA-A and another Context for the operation of ASA-B.
Marvin Rhoads Wed, 03/19/2014 - 06:28
  • Hall of Fame,
Good suggestion, Karsten.
The only caveat that brings to mind is that remote access VPN isn't supported in multi-context mode. So if that's in use they couldn't go that route.
p.s. hope to see you at Cisco Live this year.
