standard phone in paralell of a fxo card
Mar 17th, 2014
for security reason i need to have a 'normal' fxo phone in parallel of a fxo port on a 2911.
the idea is to be able to see incoming call even in case of 2911 failure.
the 2911 is working as stand alone and not managed by call manager.
it receive fxo call and forward it in sip to another system.
the problem is
when incoming call ocuured the fxo standard phone rings only once after that the cisco 'take ' the call, in fact hook off it even if the distant still hear a ring back tone.
so my security phone is not security anymore as it only ring once
is there a setting to avoid that
i found this parameter
ring number x
documents says x is the number of rings the cisco waits to answer the call. but does it mean that the cisco will not manage at all the call and send sip invite to the second system?
my voice port is defined as this
voice-port 0/0/0
 translation-profile incoming fxo-0-0-to-sip
 supervisory disconnect dualtone mid-call
 non-linear threshold -30
 no vad
 cptone GB
 timeouts call-disconnect 5
 timeouts wait-release 5
 connection plar 984
 impedance complex2
 description *** FXO Port 0-0 ***
 caller-id enable
thanks
Alain
Jonathan Schulenberg Mon, 03/17/2014 - 05:22
  • Cisco Designated VIP,
    2017 IP Telephony
Add the 'opx' keyword to the end of your connection plar command.
connection plar 984 opx
alaincayron Mon, 03/17/2014 - 06:50
Jonathan so it means the hook off will only appears when my sip extension will answer the call?
i look at syntax is it not
connection plar opx 984
and not connection plar 984 opx?
