guest vlan
Mar 18th, 2014
Hi, I have setup a vlan interface for our guest wifi. Our internal network uses the outside interface IP for it's NAT. I would like the guest network to use a different IP address.
If I specify the IP address to use, it does not work. If I change it to interface, it uses the outside interface IP, so I know there is no connection or ACL issue.
ciscoasa# sh nat
Manual NAT Policies (Section 1)
1 (Inside) to (Outside) source dynamic any interface
    translate_hits = 13501514, untranslate_hits = 535835
2 (Inside) to (Outside) source static NETWORK_OBJ_192.168.21.0_24 NETWORK_OBJ_192.168.21.0_24   destination static NETWORK_OBJ_10.10.251.0_24 NETWORK_OBJ_10.10.251.0_24 no-proxy-arp route-lookup
    translate_hits = 0, untranslate_hits = 20810
3 (GuestVLAN) to (Outside) source dynamic any EXT_outside_29
    translate_hits = 274, untranslate_hits = 0
EXT_outside_29 is the external IP address I want to use. I can see the translate_hits is counting the traffic, but nothing is working.
I'm sure this is something simple. Any guideance would be fantastic.
FYI, running ASA version 8.6(1)2
Jon Marshall Tue, 03/18/2014 - 08:02
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Is EXT_outside_29 from the same range as the outside interface IP ?
If possible could you post the full config ?
Jon
Related Content
