Cisco 1532E Mesh APs
Mar 18th, 2014
Does anyone know if the dual-band can be configured once the 1532E is in autonomous mode ?
To use the AIR-ANT2547V-N antenna. I need to configure dual-band for the anntennas.
I only found this page:
http://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/7-6/b...
and it gives only the controller commands to use when the AP has capwap software installed.
this is the capwap command:
(Cisco Controller) >config ap antenna-band-mode <single|dual> <ap_name>
they don´t mention autonomous....
The reason why am wondering is to do site surveys without "draging" the controlller with the survey kit and use the AP as autonomous.
kristjan.edvardsson Tue, 03/18/2014 - 18:38
I found it!
global config mode:
dot11 ant-band-mode dual
that saved my controller-less survey day! :)
