Warning message
VRF NAT Translation / Port Translation
Answered Question
Mar 18th, 2014
I recently moved the subnet 10.0.50.0/24 into a VRF.  After doing so I realized this broke one of my NAT translations:
ip nat inside source static tcp 10.0.50.230 22 interface GigabitEthernet1/1 9022
I located the following document: http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ipaddr_nat/configuratio...
It shows different types of NAT translations for VRF's, but not what I am looking to do exactly.  Can someone assist me in getting the above NAT translation to work with a host that is in a VRF?
Thanks!
Correct Answer by paul driver about 3 years 5 months ago
Hello
As I stated previously "need to specify a static inside global address instead of the interface"
example:
ip nat inside source static tcp 10.0.50.230 22 192.168.100.100 9022 vrf EXAMPLE
res
Paul
Overall Rating: 5 (3 ratings)
paul driver Tue, 03/18/2014 - 08:42
  • Green, 3000 points or more
Hello
When using static NAT & VRF,  I think you need to specify a static inside global address instead of the interface to use the vrf option
ip nat inside source static tcp 10.0.50.230 22 x.x.x.x 9022 vrf XX
res
Paul
Jeffrey Simon Tue, 03/18/2014 - 09:15
Does not appear to be supported:
cda6503a(config)#ip nat inside source static tcp 10.0.50.230 22 interface gigabitEthernet 1/1 9022 ?
  <cr>
Correct Answer
paul driver Tue, 03/18/2014 - 09:39
Hello
example:
res
Paul
Jeffrey Simon Tue, 03/18/2014 - 09:51
Thank you, I did not understand what you were saying.  This is working now.  Thank you very much for the help.
Related Content
