CUCM 9 Directory
Mar 19th, 2014
Hi all,
I have a CUCM v9, connected and synchronized with Microsoft LDAP correctly. When I hit the Directory Button for the first time, It take a long time to respond to my request, and after that I can get response quickly. I'm asking if there is something wrong, or it's a normal behaviour from CUCM?
Med
Jaime Valencia Wed, 03/19/2014 - 06:42
  • Cisco Employee,
  • Hall of Fame,
    2011
No, are you using IP or hostname?
What's the CPU utilization on the server?
What's between the phone and the CUCM server?
m.elmaaroufi Thu, 03/20/2014 - 04:27
And thank you for your feedback, in my case, I use IP addressing between CUCM and all the endpoints, the CPU is normal. I don't know if the CUCM try to download the LDAP directories after every first request, or there is another issue that cause this delay.
Med
Chris Deren Wed, 03/19/2014 - 06:47
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Sounds like DNS resolution is taking long time, best way to prove it would be to put a PC with wireshart on the back of the phone and trace the request and look for DNS packets.
Chris
