Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1927371members
1240033discussions
Community Activity
Allow ISE captive portal DNS entry on outside DNS.
Hello,We are having ISE for EAP/TACACS authentication and, hosted internally in our datacenter.Now we have configured BYOD captive portal that tied to AZURE SAML authentication, the current captive portal redirect URL from ISE has prepended the node ...
kshah2589 by Level 1
  • 1410 Views
  • 22 replies
Site-to-Site IPSec with VTI - Initial delay up to 60 seconds
Hello,I have an IKEv2 Site-to-Site IPSec tunnel (VTI with static routing) between ASA firewall and 2 stateless HA routers configured with HSRP (IPSec end point is HSRP VIP hosted on the HSRP active router).Despite the fact it is not stateful (not sup...
Resolved! Alternating ring
Our old work phones would take turns around the room. I don't think it was called hunt group, but once logged in to your group/extension...it would go around the room on whose turn it was to answer. Is there a way to do that? Thanks
Secure Client 5.1.1.42 with NAM and tethering to iPhone iOS 17.2.1
We have tried upgrading from Cisco AnyConnect 4.10.07073 to Secure Client 5.1.1.42 with NAM connecting to wired and wireless networks.After the upgrade NAM fails to acquire the IP address from the phone.Connecting to enterprise EAP SSIDs and other us...
PeterLMSD by Level 1
  • 1490 Views
  • 12 replies
CDP/LLDP Neigbor Details
Hi Team, Two switches are connected to each and that link is a trunk port between those two switches, The challenge is on one switch when I perform cdp/lldp neigbor detail I can see the other switch which is connected to it but funny thing when I pin...
Setting a GRE tunnels between a NAT to a public IP.
Hi everyone.. i have been looking through multiple posts on the forum for similar cases but have not found the answer Im looking for.. I've been primarily using this thread for guidance. https://community.cisco.com/t5/networking-knowledge-base/settin...
jonmo2578 by Level 1
  • 31 Views
  • 1 replies
MTU for SVL
Is it necessary to change the MTU for SVL links in a scenario in which interfaces are configured with MTU larger than default 1500 bytes?Traffic could flow between chassis through SVL links in a Stackwise Virtual cluster. Could not find any reference...
ckuwajima by Level 1
  • 86 Views
  • 3 replies
Creating public space with restrictions
Hi, I would like to create a public space where the members/admins can chat and they are the only ones who can see it and all the others can post and they can see the answers only. I do not know whether it is possible or not. Any thoughts welcome.Tha...
Cocokey by Level 1
  • 45 Views
  • 1 replies
AnyConnect Speed Issues
Hello,FTD's 2110 at 7.3.1.1.I have two datacenters running that code on 2110s. They have the same configuration for the most part and the same size fiber internet 500 Mbps circuit. Coming in on VPN1, running a speed test from my home connection is ab...
dcanady55 by Level 1
  • 43 Views
  • 0 replies
