Use of BAT file - How do you completely delete 150 phones and their associate DNs?
Answered Question
Mar 19th, 2014
How do you completely delete 150 phones and their associate DNs? All the phones are in the same device pool. I prefer BAT way.
Version of the CUCM: 8.6.2
Type of phones: 7962 phones - associated with the same device pool.
Additinal questions: Is there a way to delete elegantly all the phones and their associated DNs when all the phones are associated to the same device pool? I rather not work with specific extensions and MAC addresses.
Thank you,
Calin Lupas
Correct Answer by Rob Huffman about 3 years 5 months ago
Hi Calin,
Using BAT this will require 2 - passes. 1 for the phones and 1 for "unassigned DN's". this is nicely shown in the attached doc;
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/bat/8_0_1/bat-80...
Of course for the DN's you could delete them via the Route Plan report>Unassigned DN>select all>Delete
Cheers!
Rob
Overall Rating: 5 (2 ratings)
George Thomas Wed, 03/19/2014 - 17:03
  • Blue, 1500 points or more
I would do an export of the phones, sort by Device pool, remove the rest of the phones and massage the BAT file a bit so that it only contains the fields that BAT require BAT for the deletion job.
Calin Lupas Thu, 03/20/2014 - 05:34
Is there a way to delete the associated DNs on the phones when I delete the phones?
Correct Answer
Rob Huffman Thu, 03/20/2014 - 07:41
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Calin,
Cheers!
Rob
Calin Lupas Thu, 03/20/2014 - 08:03
Thanks Rob. Looks like there is a need for a 2 BAT files.
Delete-unassigned-DNs method does not work well for us since our CUCM is not extremely clean.
Is there a way to somehow collect all the DNs associated with all the phones in the device pool? This way, I could easily create the BAT file for the future unassigned DNs.
Calin
Related Content
