Warning message
HELP - Licence Error on 4500x VSS
Mar 20th, 2014
HI there,
have 2 4500x in vss mode. both are running 3.4.2 ipbase and are running on the correct licences etc.
after putting them in VSS mode the following error shows in the logs.
%SW_LEVEL-6-RESULT: Operational redundancy mode is UNKNOWN, due to software license-level mismatch at ACTIVE and STANDBY. Software Level on Active: ipbase; on Standby: ipbase
Any suggestions would be appreciated.
I thought it maybe related to bug CSCui54147 but cant see any details of it and it only seems to relate to 3.5.x
Thanks in advance.
Ross
Reza Sharifi Thu, 03/20/2014 - 11:45
  • Cisco Designated VIP,
    2017 LAN
Hi Ross,
Can you post the output of "sh switch redu"?
Ross Phillips Tue, 04/15/2014 - 08:33
Hi Apologies for not getting back.
To fix this I had to manually accept the EULA for ipbase licence on the 4500x.
After the reload everything worked correctly and I stopped getting this error.
Related Content
