Warning message
****CUCM CALL SETUP****
Mar 20th, 2014
Hi all,
For trubleshooting purposes, i am trying to get a way to have CUCM to display the call setup process and MOS score after the call had been established( same result as Asterisk -R )... Is there a specific commands or steps to accomplish..
Jaime Valencia Thu, 03/20/2014 - 16:04
  • Cisco Employee,
  • Hall of Fame,
    2011
Look at CUCM traces for call setup, and CMR/CDR for call quality.
Jean Paul Enerst Fri, 03/21/2014 - 09:40
I  was looking for live call setup to see the handshake between the device.
I am sure if you are familiar with asterisk, in Asterisk if login to the back end server and issue asterisk -R. You can see all live calls...
The CDR give the result after the fact.
Thanks Jaime
Jaime Valencia Fri, 03/21/2014 - 09:45
  • Cisco Employee,
  • Hall of Fame,
    2011
I'm not familiar with asterisk, but with the amount of logs a single call generates in CUCM, hardly anyone uses that method, you can also do that via RTMT, if you can keep track of the process
