03-20-2014 04:13 PM
hello, i have one RV110W router and i need configure this with WDS, but when i want check the option "Allow wireless signal to be repeated by a repeater", this is gray and i can´t select it.
Can you help me?
thank you
regards
02-17-2015 04:06 AM
Did you figure it out?
Try resetting to factory defaults and check if that works?
Thanks.
02-17-2015 07:16 AM
My name Eric Moyers. I am an Engineer in the Small Business Support Center.
I realize that this post was from 11 months ago, but answering just in case it helps someone else.
The only time that I have ever seen this exact issue was when under Wireless - Basic Settings: Radio was disabled.
Eric Moyers
.:|:.:|:. CISCO | Cisco Presales Technical Support | Wireless Subject Matter Expert
Please rate helpful Posts and Let others know when your Question has been answered.
