Warning message
Reload Access Points after enabling broadcast of SSID
Answered Question
Mar 21st, 2014
Hi, we've created a SSID, which is not being broadcasted. Now I would need to enable broadcast of the SSID-so my question is: how will the access points act after enabling it? Will they reboot automatically?? Or do they even need to be rebooted?
Thanks!
KR
Correct Answer by Leo Laohoo about 3 years 4 months ago
If that is the case, then the answer is "No".  Changing the settings of the SSID will NOT reboot the AP.  HOWEVER, bear in mind that changing any settings in the SSID will cause the SSID to go down/up.  This is an expected behaviour.
Hope this helps.
Correct Answer by Rasika Nayanajith about 3 years 4 months ago
No, that will not reboot your AP. You can safely enable or disabel this feature without any issue
Rasika
**** Pls rate all useful responses ****
Overall Rating: 5 (2 ratings)
Sandeep Choudhary Fri, 03/21/2014 - 09:13
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 Wireless
for broadcast a ssid , there is no need for reload.
what you need for broadcast:
mbssid guest-mode <– Only required multiple SSID to be broadcast.
If it is only single SSID this needs to be “ ssid guest-mode”!
Check more here: http://mrncciew.com/2012/10/24/multiple-ssid-config-on-autonomous-ap/
Dont forget to rate helpful posts
Leo Laohoo Fri, 03/21/2014 - 15:02
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
    2017 LAN, Wireless
This will depend on whether or not you're using autonomous AP or controller-based AP.
If you have controller-based AP and you are using AP Groups, the change from the default-groups to a different AP Group will reboot the AP.
Rene S. Fri, 03/28/2014 - 06:10
They're controller based, but I wouldn't change anything regarding AP groups, I'd just check the "Broadcast SSID" checkbox.
Correct Answer
Rasika Nayanajith Fri, 03/28/2014 - 11:47
    2017 Wireless
Rasika
Rene S. Thu, 04/10/2014 - 10:45
Hi, only the affected SSID went down - for about 5-10seconds. No reboot.
Thanks again!
KR
Correct Answer
Leo Laohoo Sat, 03/29/2014 - 15:24
  • Hall of Fame,
    2017 LAN, Wireless
Hope this helps.
Rene S. Sun, 03/30/2014 - 23:02
ok, thanks for your answers. I'll enable the broadcast and will let you know how what really happened. I also expect the SSID to go down/up.
Scott Fella Sun, 03/30/2014 - 08:39
  • Hall of Fame,
    2017 Wireless
Just to add.... if your enabling broadcast, from a client side, they will only see a glitch in the network, but if your disabling broadcast, then you will have to reconfigure your deives.  If a profile was created on a device when broadcast was enabled, then the profile will not check if the ssid is not being broadcasted.  So just be careful with that.
Chatura Fernando Sat, 03/29/2014 - 05:09
I assume you are talking about a WLC based LAP environment. The option is available under Wireless tab.
Onve the "Broadcast SSID" is ticked, the SSID will reload and clients will lose connections.
if there are Multiple SSID's the other SSID's wont get afected nor the access points.
This change will NOt restart the LAP's.
chatura
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
