Warning message
CUSP 8.5.6 (sip proxy) change calling number
Mar 21st, 2014
We use CUSP (Sip Proxy) for outgoing calls.For each outbound compaign we need use specific calling number. Where I can change calling number in cusp (sip proxy) settings?
Omar Deen Fri, 03/21/2014 - 09:59
  • Silver, 250 points or more
That all depends on how your carrier service is set up. If your carrier allows you to present the calling line ID from your premise equipment, then it could be set by whatever is making the outbound call, which is usually CUCM if it's just a phone. This can be overriden on your route pattern or trunk to the gateway in CUCM or at the dial-peer of the gateway. It just all depends on how you're stuff was configured.
Andrey Tereschenko Mon, 03/24/2014 - 01:49
I have ipphone - callmanager - sip proxy - cisco 5300 with e1
I want change calling number on SIP Proxy (not callmanager, not voice gatway). How I can change calling number for example 1888 on 55551888.
where and what settings I can do? Thanks.
