Warning message
Sandeep Choudhary Fri, 03/21/2014 - 11:25
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 Wireless
Normally not. I did this many times.
Just after new upgarde WLC need to be reboot, that make AP reassociate with new software version with many new features.
Sometime you can see the config difference.  This is because there are configs from the 7.6 that the 7.4 wouldn't understand.
Under normal circumstances, this should be fine.  But there are some cases that this can cause issues.
so keep your config as backup.
Dont forget to rate helpful posts
Sandeep Choudhary Fri, 03/21/2014 - 11:26
    2017 Wireless
1marke Fri, 03/21/2014 - 11:48
Thank you.
I did read the part about a backup config and that makes good sense.
We will be doing that as well.
Thanks again for the verification.
Trending Topics - Security & Network
