Warning message
CUBE DSPs / PVDMs
Mar 21st, 2014
I need some calrity, the cost is huge.  When I'm doing CUBE.  Assuming I'm running G.711 on both sides (no transcoding) and I don't need any MTP (conferencing, etc.) do I need DSPs on a CUBE router?  Does DTMF inband vs. out of band have any affect?  Is there a good guide that shows when I need DSPs and when I don't when using CUBE for my SIP trunk?
Chris Deren Fri, 03/21/2014 - 14:01
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
No PVDMs are needed if you are not doing transcoding, MTPs can be either hardware (PVMD), software IOS (using router CPU, no PVDM, recommanded) or CUCM software. The CUCM SRND has a good section on this topic under media resrouces section.
Chris
