Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1928826members
1242661discussions
Community Activity
Stop in progress template provisioning
Hello everyone.  I'm very new to DNAC or Catalyst Center.  I've setup a project with a template to add a simple configuration to switches.  It currently has been in progress for 10 days and hasn't made a change to a switch yet.  I'd like to cancel th...
Gricel by Level 1
  • 33 Views
  • 1 replies
Cisco CM Switch Box
Our Forum Alert III Secondary Crash Net (SCN) is inoperable. I've heard the cisco cm could be configured to set up some devices to act as a ringdown, they called it a “Switch Box.” This would allow our Base Operations guys to have a work around from ...
unknown IPs in FTD outbound logs
I am managing FTD-1120s with FMCv both running v7.2.1 software.  In my ACP I have a GEO rule to block all outbound traffic to China, Russia, and I few other "hotspots".   When I search for events that match this rule, most of the traffic is from inte...
tato386 by Level 6
  • 162 Views
  • 6 replies
  • 1 Helpful votes
IP routing using domain
The host for my current server (Windows Hyper-V machine with four or five VMs) that handles my email and web sites is going away. I'm planning on moving that physical server to my house and using DDNS to route that traffic in. Realize this is very lo...
Configuring NAT overload with vrf lite on a CAT9K
Good day;Need help with how I can configure NAT overload with an existing vrf on a CAT9K_IOSXE V16.12.  This is what I am struggling with, I currently have a vrf called AWSDX-S3.  Now what I am trying to do is I have added a L2 SW and ran trunk ports...
gurowar by Level 1
  • 290 Views
  • 12 replies
Extremely slow and poor overall WiFi quality with C9130AXI
Recently swapped our 3802i APs for all C9130AXI to get the WiFi 6 capability. Have noticed very poor performance overall. Only change has been with the APs, nothing else. The controller remained to be an AIR 3504 and the switch is a Catalyst 3850 UPo...
NexCyb by Level 1
  • 4 Views
  • 0 replies
Cisco Secure Client CVE-2024-20337
Following upgrading to upgrading to 5.1.2.42 to fix the vulnerability CVE-2024-20337Within Microsoft Defender this is still flagged as vulnerability for the CVEIt appears to refer to a component of the install:C:\Program Files (x86)\Cisco\Cisco Secur...
ansto by Level 1
  • 223 Views
  • 6 replies
Recording Jabber - Overlapping Voices
Hello, I'm having this situation:In the call center we have PCs with softphones installed (Jabber) that replicate the traffic to a recorder in another site.Randomly, we are seeing high levels of Jitter in the flow that is replicated to the communicat...
Help with routing vlans
Can someone tell me how do I do routing here ? it does not matter if it is static or dynamic I just want to ping same vlans and also I dont want to have different vlans to be pinged
CUCM HUNT GROUP AND INTERCOM CALLS
Hi to allMy question is very simpleIntercom working fine , but the issue is that you can call only one intercom phoneWhat is the requirement if i want to perform an intercom call to a multiple phonesDoes this work with Hunt group?Regards
