Warning message
Leo Laohoo Sun, 03/23/2014 - 14:27
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
If you are talking about the flash card INSIDE, then yes. You can move them from one identical router to another one.
wynholds Sun, 03/23/2014 - 16:31
Yes, I was referring to the INSIDE flash card.  The old router failed and I need to replace it.  With the flash card swap, this should be a trivial task.  Thank you for your prompt reply.
Aman Soi Mon, 03/24/2014 - 10:00
  • Purple, 4500 points or more
    2017 IP Telephony
you can do that.Make sure the CF to be inserted has same IOS image as the faulty CF because of any specifc feature which is working with faulty CF  and needs to be supported with new CF as well.
regds,
aman
Leo Laohoo Mon, 03/24/2014 - 14:47
  • Hall of Fame,
    2017 LAN, Wireless
It doesn't matter where you transfer the internal flash card to.  At the end of the day, you can boot the IOS from the internal flash and the external flash and this is done by setting the correct boot string variable.
Related Content
