Warning message
Cisco 3550-PWR SSH problem
Answered Question
Mar 24th, 2014
I'm struggling to make SSH work on Cisco 3550-PWR router.
It has SSH 1.5/1,9 and complains to generate 768-bit key when I try to activate SSH 2. Even after I generate the keys, it still complains.
I'm able to SSH in using 1.5/1.9 but not 2 yet.
It's been a while since I've done R&S and could use a little help.
Thanks.
Correct Answer by Richard Burts about 3 years 4 months ago
It is good to know that SSH 1 works. This output
SSH Enabled - version 1.99
usually indicates that the device will accept both SSH 1 and SSH 2. So I am puzzled why SSH 2 is not working. In the original post you tell us "complains to generate 768-bit key when I try to activate SSH 2". I am not sure what that is about. Can you tell us what modulus was used to generate the SSH/RSA keys?
What happens if you generate new SSH/RSA keys and specify modulus 2048?
Rick
Overall Rating: 5 (1 ratings)
AFROJ AHMAD Mon, 03/24/2014 - 22:56
  • Cisco Employee,
Hi ,
share the outputs from the : "debug ip ssh " command
what is the version of code you are running ?
do you see  "no exec" configured under his vty lines.  if yes remove it and then try again
Thanks-
Afroz
***Ratings Encourages Contributors ***
sendalot7 Tue, 03/25/2014 - 06:40
Cisco IOS Software, C3550 Software (C3550-IPBASEK9-M), Version 12.2(44)SE6, RELEASE SOFTWARE (fc1)
I don't see any output from "debug ip ssh."
SSH1/1.5/1.9 works but not 2, can't activate it.
This is "show ip ssh"
Authentication timeout: 120 secs; Authentication retries: 3
Correct Answer
Richard Burts Thu, 03/27/2014 - 07:15
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Rick
sendalot7 Thu, 03/27/2014 - 07:21
Not sure what happened but after a restart and some miralce, SSH-2 not works.
I created 768 bit key bunch of times, etc.
Thanks!
Richard Burts Thu, 03/27/2014 - 07:54
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
I am glad to know that SSH 2 has started to work. Sometimes a restart will get things synced up and working that had been somehow out of sync before. Perhaps it was something like that. Thank you for using the rating system to mark this question as answered.
Rick
vishal vyas Wed, 03/26/2014 - 17:59
try to add command under line vty
line vty 0 4
tranport input ssh
