03-25-2014 05:50 AM
I am trying to apply netconfig to some devices through RME , however i can see the devices but not able to select them
the checkbox is disabled
any suggestions
03-25-2014 06:28 AM
Try updating the RME device pacakges from common service > software center >device update
Thanks-
Afroz
***Ratings Encourages Contributors ***
03-26-2014 04:54 AM
Any other suggestions apart from updating ?
03-26-2014 07:50 AM
I think this is the same server , LMS 3.1 ?
Try deleting and re-adding the device ,if that did not help . you have to update the RME device pacakges or as I suggested in a previous post upgarde the LMS to atleast 3.2.1 ,if it is the same server.
Thanks-
Afroz
03-26-2014 11:40 PM
yes it is the same 3.1
Can you please provide the download link to LMS 3.21 , i can only find the link to evaluation version.
Will license file for 3.1 work on 3.2.1 ?
Can i Migrate the dabase of 3.1 to 3.2.1 (any link will be highly helpful)
Also which OS is required for 3.2.1 ? i remember tht 3.1 wasnt working on Windows 2008 R2 so have to install it on 2003 R2
03-27-2014 01:18 AM
Hi ,
You need to go on 3.2 fisrt. I did not find 3.2.1 on the cisco.com .
Installed 3.2 first and hope this will resolve many of the issues you are facing:
here is the download link for 3.2 :
http://software.cisco.com/download/release.html?mdfid=282635181&flowid=16561&softwareid=280775102&os=Windows&release=3.2.0&relind=AVAILABLE&rellifecycle=&reltype=latest
yes the license for LMS 3.1 will work perfectly on LMS 3.2
Hardware should not be a problem:
http://www.cisco.com/c/en/us/td/docs/net_mgmt/ciscoworks_lan_management_solution/3-2/install/guide1/lmsigsg/prereq.html#wp1101012
NOTE: before you actually planned to upgarde , take the backup of LMS 3.1 and then start the upgarde.
For data migration , check the below link:
http://www.cisco.com/c/en/us/td/docs/net_mgmt/ciscoworks_lan_management_solution/3-2/data_migration/guide/lms32_dmg/dmg_win.html
Thanks-
Afroz
[Do rate the useful post]
03-27-2014 04:45 AM
Thanks Afroz , will try out this and post the result
04-18-2014 10:36 PM
Upgraded to 3.2 , however i am receiveing DCR Server is down or inaccessible.
any suggestions ?
04-19-2014 01:27 AM
Hi ,
share the below information:
output of pdshow
dcrserver.log
md.properties
regdaemon.xml and regdaemon.xml.bck
ctm_config.txt file from below location :
NMSROOT\\CSCOpx\\MDC\\tomcat\\webapps\\cwhp\\WEB-INF\\lib
NMSROOT\\CSCOpx\\MDC\\tomcat\\shared\\lib
Thanks-
Afroz
04-20-2014 09:53 PM
04-20-2014 10:07 PM
Hi ,
ERROR: Certificate Date Invalid
java.security.cert.CertificateNotYetValidException: NotBefore: Thu Apr 10 12:05:14 PDT 2014
certificate seems to be invalid ..
Regenerate the SSL certificate as below ::
To generate a new certificate in LMS
1. Stop the daemon Manager
net stop crmdmgtd
1. Remove the following certificate files from (NMSROOT/MDC/Apache/conf/ssl)
a. server.crt
b. server.key
c. server.pk8
d. server.csr
2. Disable SSL:
NMSROOT\CSCOpx\bin>perl "NMSROOT\CSCOpx\MDC\Apache\ConfigSSL.pl" -disable
3. Enable SSL to generate certificate:
NMSROOT\CSCOpx\bin>perl "NMSROOT\CSCOpx\MDC\Apache\ConfigSSL.pl" -enable
4. Start Daemon Manager
net start crmdmgtd
Also change the last line in the ctm_config.txt file , it should have 2 back slash:
REGISTRY_LOCATION=C:/PROGRA~2/CSCOpx//MDC/tomcat/webapps/triveni/WEB-INF/lib
it should be
REGISTRY_LOCATION=C://PROGRA~2//CSCOpx//MDC//tomcat//webapps//triveni//WEB-INF//lib//
Thanks-
Afroz
04-21-2014 10:05 PM
Thanks AFroz,
i did all the steps , started the daemon , restarted the server as well as i am getting the following error
You don't have permission to access /cwhp/LiaisonServlet on this server.
Additionally, a 403 Forbidden error was encountered while trying to use an ErrorDocument to handle the request.
04-21-2014 10:47 PM
You are using 443 or 1741 ?
as ssl is enable , use the port no . 443
if above is not working . Just disable the SSL once and then try login with 1741
steps:
net stop crmdmgtd
2. Disable SSL:
net start crmdmgtd
Thanks-
04-21-2014 11:11 PM
Did the same thing ,i was using 1741
disabled SSL and restarted Daemon , again got back to DCR error
DR Server Process status is "Waiting to Initialize"
04-22-2014 03:53 AM
hi ,
ctm_config.txt file from below locations :
send both the files from the above location.
and dcrserver.log and dcr.log
Thanks-
Afroz
