WAAS upgrade from v4.4.3b1 to 5.3.5b31
psoares123
Hi.
I'm doing an upgrade to a WAAS solution from v4.4.3b1 to v5.3.5b31.
The Solution is composed by 2 Central Managers WAVE-574-K9, 3 WAE Data Center WAE-674-K9 and 25 Banches SRE modules into 2911 routers.
For the upgrade I begin by Central Managers and after the upgrade to CMs brunches start to fleack offline and then online again on CM.
I tryed to reload SRE module in some branches and didn't resolve.
Some brunches didn't had any complain.
Anyone have an ideia of what can be the problem?
Follow the output of show cms info in SRE branche with problem:
XaiXai-WAE-01#show cms info
Device registration information :
Device Id                            = 15406
Device registered as                 = WAAS Application Engine
Current WAAS Central Manager         = 10.111.61.113
Registered with WAAS Central Manager = 10.111.61.113
Status                               = Pending(CM is busy, retry later)
Time of last config-sync             = Tue Mar 25 21:47:26 2014
CMS services information :
Service cms_ce is running
pevaneyn
When I see 5.3.5 and 674 I think of CSCun85976. Are you using an inline card on that device?
Otherwise I would do a 'cms deregister force' on the SRE, followed by an identity recovery, see: http://www.cisco.com/c/en/us/td/docs/app_ntwk_services/waas/waas/v531/configuration/guide/cnfg/maint.html#wp1105458
Best regards, Peter
