HVC330 not able to call polycom hdx
r.kukreja
hi,
we are not able to dial our polycom HDX 7000 125.19.x.x##3456 from HVC330  aver video conference system.
we are getting below logs
Call-Status: Incoming Q.931 TCP connection established
Termination Cause: Cannot find client
kindly share experience
regards
rajat
6 Replies 6
Wayne DeNardi
This is a Cisco forum, so there's probably not too many people who have a lot of experience dealing with interaction between two non-Cisco manufacturer's devices - perhaps a Polycom or AVER forum would be a better place for your question.
In any case, the <IP Address>##<number> format is a Polycom specific dialing extension - does it work if you specify a proper URI such as 3456@125.19.x.x ?
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Apr  2 16:36:06 2014 VBP mand: Ending call ID 271 between 212.154.22.78 and 172.26.160.6.  MOS scori
ng is enabled.  Remaining active calls=4.
Apr  2 16:36:06 2014 VBP mand: Ending call ID 269 between 212.154.22.78 and 172.26.160.6.  MOS scori
ng is enabled.  Remaining active calls=3.
Apr  2 16:36:06 2014 VBP mand: Ending call ID 270 between 212.154.22.78 and 172.26.160.6.  MOS scori
ng is enabled.  Remaining active calls=2.
Apr  2 16:36:06 2014 VBP mand: Call ID 268 172.26.160.6->212.154.22.78: Call complete.  No MOS score
 generated, codec unsupported.  Remaining active calls=1.
Apr  2 16:36:06 2014 VBP mand: Advanced MOS (v1.5);STR=1396455918;STP=1396456566;Call ID=268;SRC=172
we are not able to call from aver system still. the above logs are in the  VBP
can any body share experience.
regards
rajat
Is the problem you're having only calling from the AVER to the Polycom, or does it occur when you call the other way as well?
Are all of your devices running recent versions of the software for those endpoints?
How are they conencted to each other (is there any VCS / gatekeeper / etc in between).
Are you calling over ISDN or an IP Network?
What protocol are you using for the call (H.323, SIP, H.320).
Teh more information you can provide as to how your devices are connected and trying to communicate to each other may help identify where the issue is.
Again, as they're all non-Cisco devices - you may have more luck with getting an answer on a Polycom or AVER forum, but we'll try out best.
Wayne
Wayne
thanks for your response
getting problem from aver to polycom calling
aver is in turkey end polycom in india end
aver is not registered to any gatekeeper
protocols are only h.323 and sip
ip network we are using
i try to call from aver 3456@12519.X.X
but not get success. it hit at my VBP device and above are lthe logs of VBP device
please help to resolve
regards
rajat
As before, are you able to make the call in the opposite direction?
1) If you call Polycom to Aver does it work?  Does it work for both SIP and H.323?
2) If you call Aver to Polycom does it work?  Does it work for both SIP and H.323?
3) Are the firewalls on either of the sites showing any drops of packets?
4) Is the site with the gatekeeper showing the call inbound/outbound?
5) Is the NAT setup on the AVER without the gatekeeper set up correctly?
You may have more luck asking on the Polycom Support Community web site for issues with your Polycom equipment: http://community.polycom.com/
Wayne
Wayne
Thanks so much.  I had a similar issue calling RMX system and this helped me.
