Warning message
Problem for configuring DHCP IPV6 on my router
Mar 27th, 2014
Hi everybody,
I try to test DHCP IPV6.
My topologie is very simple :
 CustomerA <--------------------------->R_IPV6
 - Customer is Linux debian
- Router is 7200 >>> Version 12.4(25f)
I read the documentation
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ipv6/configuration/12-4...
I try to configured server DHCP IPV6, but I don't see all command !!!!
router_A(config)#ipv6 dhcp pool client_siteA
router_A(config-dhcp)#?
IPv6 DHCP configuration commands:
  default            Set a command to its defaults
  dns-server         DNS servers
  domain-name        Domain name to complete unqualified host names
  exit               Exit from DHCPv6 configuration mode
  no                 Negate a command or set its defaults
  prefix-delegation  IPv6 prefix delegation
  sip                SIP Servers options
I don't configured the  address prefix ???
Why ?
Bad version ?
My configuration
router_A#sh run
Building configuration...
Current configuration : 1297 bytes
version 12.4
hostname router_A
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
ip domain name lab.local
ipv6 unicast-routing
ipv6 cef
 dns-server 2001:4860:4860::8888
 dns-server 2001:4860:4860::4444
 domain-name nantes.net
interface FastEthernet0/0
 no ip address
 duplex auto
 speed auto
 ipv6 address FC00:1::1/64
 ipv6 ospf 1 area 0
interface FastEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
interface FastEthernet1/0
 description Site-Local
 no ip address
 duplex auto
 speed auto
 ipv6 address FC00::1/64
 ipv6 nd managed-config-flag
 ipv6 nd other-config-flag
 ipv6 dhcp server client_siteA
interface FastEthernet1/1
 no ip address
 shutdown
 duplex auto
 speed auto
ip forward-protocol nd
no ip http server
ipv6 router ospf 1
 router-id 1.1.1.1
 log-adjacency-changes
 redistribute connected
control-plane
line con 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
 escape-character 3
 stopbits 1
line aux 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
 stopbits 1
line vty 0 4
 login
end
a.auvinet Thu, 03/27/2014 - 01:40
It's OK with :
 no ip address
 duplex auto
 speed auto
