Warning message
(No Title)
Answered Question
Mar 27th, 2014
Hi, i can't delete Calling Search Space (CSS) from the CUCM page, i have this message:
Delete failed. The pkid column in the callingsearchspace table in the database is being
referenced from another table. Please check the dependency records, remove the reference,
and then try the delete again.
I want to delete the CSS named: CSS-Fax-Boulogne
With the CUCM's CLI i use this command:
- run sql select * from callingsearchspace
and seen this: 353428bb-31e8-5745-406a-df73f0050af6 CSS-Fax-Boulogne                NULL
But when i use this command:
admin:run sql select fknumplan from callforwarddynamic where fkcallingsearchspace_cfa = "353428bb-31e8-5745-406a-df73f0050af6"
fknumplan
admin:run sql select dnorpattern from numplan where pkid = "353428bb-31e8-5745-406a-df73f0050af6"
dnorpattern
admin:
i have no result, can you help me please for delete the unsed CSS?
Correct Answer by Chris Deren about 3 years 4 months ago
check to ensure there are no BAT templates referencing it.
Chris
Overall Rating: 4 (2 ratings)
Correct Answer
Chris Deren Thu, 03/27/2014 - 06:37
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Chris
Gilles Dellaccio Thu, 03/27/2014 - 07:07
I had already looked at this post before open my post
but thanks for your reply
Gilles Dellaccio Thu, 03/27/2014 - 07:08
Thanks a lot, i find this CSS in Templates and device Pool, et CSS Subscriber of device.
