Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1915037members
1215807discussions
Community Activity
18557384481 how do i connect with people on 𝗞𝘂𝘄𝗮𝗶𝘁 𝗔𝗶𝗿𝘄𝗮𝘆
Passengers can call 헞혂현헮헶혁 헔헶헿현헮혆혀 by dialing the 24x7 헞혂현헮헶혁 헔헶헿현헮혆혀- + ퟭ-ퟴퟱퟱ-ퟳퟯퟴ-ퟰퟰퟴퟭ (Live agent) and get a quick answer on the call. You can get 24-hour immediate assistance on your query. How do I talk to a 헞혂현헮헶혁 헔헶헿현헮혆혀 representative fast? 헞혂...
18557384481How Do I Connect with Someone on𝗞𝘂𝘄𝗮𝗶𝘁 𝗔𝗶𝗿𝘄𝗮𝘆𝘀
Forward Broadcast
Hello,I have subnet like this :My pc under vlan 100 (192.168.100.0/24)My NAS under vlan 150 (192.168.150.0/24)Actually when the nas and pc located under same subnet, I can discovery the nas from my laptop using vendor utility, but can't discover when...
hs08 by Spotlight
  • 26 Views
  • 1 replies
Webex API Update a Personで外線番号を剥奪した際、ロケーションに変更が生じる事象について
以下のケースで、Webex APIのユーザー情報更新API(Update a Person)で外線番号を剥奪した際、所属しているロケーションから抜けてしまい、ロケーション未所属となる事象を確認しました。外線番号を剥奪してもロケーションには変更が生じず、所属しているロケーションのままになるようにしてほしいです。【前提条件】操作対象のユーザーアカウントの状態・ライセンス:Webex Calling Professionalを所有・電話番号:内線番号と外線番号を使用・ロケーション:所属(例としてTok...
YH1230 by Level 1
  • 145 Views
  • 4 replies
No Radius Live Logs on ISE
Hello, I'm trying to configure the switch so the ISE can trust the switch. here's the topology. [ISE IP: 172.16.10.25] I'm using this config in the switch: aaa new-modelradius server ISE1address ipv4 172.16.10.25 auth-port 1645 acct-port 1646 key 0 ...
WLC Guest Auth
Hello,What should we do if sometime the web auth for guest WLAN is not showing?
hs08 by Spotlight
  • 168 Views
  • 4 replies
Finesse styles CSS file finextcommonstyles.css
Hi All, It seems there is a CSS file that contains the look and feel of Finesse which makes it easier to have gadgets look more native. The catch is it is only available as of Finesse 12.6(2) which means it is not available on previous Finesse versio...
benkirton by Level 1
  • 208 Views
  • 6 replies
ASIC speed difference
The overrun counter on the C9800 interface suggests that there might be a bottleneck in processing incoming traffic. Given that the facing switch is a C9500 with potentially different ASIC speeds, could the congestion and packet drops on the C9800 si...
wadwate3 by Level 1
  • 43 Views
  • 1 replies
