Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1927736members
1240727discussions
Community Activity
ASR1001-X Thruput only 750 meg Interfaces10G both sides -Circuit 10G
We have a Cisco ASR1001-X and it can only pass 750 megs of traffic thru it on a 10 Gig circuit. I looked at licensing levels and they seem correct. Anyone have any ideas of what I can look at? Both Lan and Wan interfaces are 10 gig and Wan is using S...
jroy777 by Level 1
  • 173 Views
  • 7 replies
Adding Backup ISP
I have a pair of ASAs that I try to add a backup ISP.   I would be creating sub interfaces on Gi0/0.  Once I default the Gi0/0, the Outside configuration would be gone from the configure, can I do the sub interfaces. configure Gi0/0.10 with nameif Ou...
ironman28 by Level 1
  • 72 Views
  • 3 replies
wifi network drops during the day - AIR-AP2802I-Z-K9
Deal All,       I would like your help regarding a problem that has been going on for a long time. Many users at the company have complained that the WiFi connection on their laptop drops several times during the day. I have been monitoring some of t...
10mb connections
Hello,On the newer switches with 2.5/5gb ports how do you handle devices that only work with a 10mb NIC?We have a HVAC controller that only has a 10mb NIc on it so the switch doesn’t detect it. Is there a device that will convert down to 10mb like a ...
pollardt3 by Level 1
  • 55 Views
  • 2 replies
C9800-80 in HA cannot install APSP6
Hello everyone,I'm trying to figure out a frustrating issue. Attempting an install of APSP6 keeps bombing out and I'm unsure what steps to take next. Software: Version 17.09.04aROM: 17.3(3r)Error in question:  Dec 13 21:21:01 Eastern: %INSTALL-3-OPER...
EEM scripting help
I'm trying to have EEM script where I run the script manually and it display the output of the results in the session but for some reason I'm unable to do so. This is what I have so far(config)#event manager applet TestCommand(config-applet)# event n...
Sunny5 by Level 1
  • 147 Views
  • 6 replies
IPSec VPN Tunnel Lan-to-Lan decrypt count zero
Hi, I have one issue with IPSec tunnel Lan-to-Lan between ASA 5525x (v9.8) and ASA FPR 2110 (v9.16). My Tunnel is up but ping between each client was not successful. Both peer status sh cry isakmp sa in "MM_ACTIVE".I ran packet-tracer icmp between pe...
El Rondo by Level 1
  • 550 Views
  • 26 replies
Update Space Classification After Creation
For those who have configured Space Classification in Control Hub. Is there a way to change the Space classification after it has been setup during the creation of the space? I noticed when I go to "edit space information" the window does not give me...
Jesse D by Level 1
  • 62 Views
  • 1 replies
The "Other" space in Messaging on Webex App
Hello Community! Pictured below is my dilemma. How do users get automatically added to the drop down in the webex app. I thought it was because they had installed the webex app but many of the users in the list do not have the app installed. Some hav...
antwilson by Level 1
  • 67 Views
  • 1 replies
Providing certificates for ASA SSL VPN Authentication
I'd like to know if it's possible to give a remote client a certificate that they can import to use for SSL VPN authentication instead of having them generate the request and giving it to us to sign and hand back to them. Using an enrollment server i...
Crag Muer by Level 1
  • 76 Views
  • 1 replies
  • 1 Helpful votes
Upcoming Event: Capture the Flag, get the Badge!
You asked, we heard you! Introducing the ThousandEyes Support Community Capture the Flag event from April 23rd at 8 AM PST to April 29th at 5 PM PST. This month the ThousandEyes Community is offering two Capture the Flag missions in a single upcoming...
SDWAN-LAB only mpls connections
hello, So in my lab i just have 3 CEDGE (CRSv) and i want to connect them to the controllers the only consideration is that the link are MPLS ONLY or in this case i put gi1 color private1  and gi2 color private2 on the SDWAN-DC device and i created r...
vivarock12_2-1713568494079.png vivarock12_3-1713568651130.png vivarock12_4-1713568817495.png
