Warning message
Kelvin Willacey Fri, 03/28/2014 - 12:40
  • Bronze, 100 points or more
It kinda depends on what type of routes you are trying to filter. What are you trying to accomplish?
swaroopaisaac Sun, 03/30/2014 - 19:48
I am looking for filtering LSAs from getting updated in the main routing table.
cadet alain Mon, 03/31/2014 - 01:13
  • Purple, 4500 points or more
if you don't want LSAs to make it in the RIB then you can use distribute-list in command but don't forget it will only be local on the router where this command is applied because LSAs will still be flooded to other routers in the area.
Could you be more precise about what you are trying to achieve with a topology and explanation.
Alain
e.ciollaro Mon, 03/31/2014 - 04:13
  • Silver, 250 points or more
Alain is right but remember that LSA-3 can be filtered on ABR. This way routes are not put in routing table and also not advertised  in one area.
