The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally. New Here? Click here to learn more and get started.
Cisco Community is an active and collaborative place to learn more about our products and ask questions of peers and Cisco experts! Check out some of the most popular conversations happening right now!
Apr 16 04:14:35.390: %SW_MATM-4-MACFLAP_NOTIF: Host 001b.0907.fe0e in vlan 11 is flapping between port Gi1/1/1 and port Gi1/1/2Apr 16 04:14:35.390: %SW_MATM-4-MACFLAP_NOTIF: Host 001b.0907.fe0e in vlan 11 is flapping between port Gi1/1/1 and port Gi1...
What is the meaning of this Alert and what can I do to mitigate this. (for Unified Access Points)Message: '802.11a/n' interface of AP 'XXX' associated to controller 'XXXX)' is down. Reason: Radio reset due to (56) Radio channel set
I'm having problems setting up my home network using Cisco2921 for the first time. It has the basic licenses only. Below is the running config followed by my adapter settings. Any assistance would be greatly appreciated. Thank you.Current configurati...
Good afternoon,A new client is splitting off from a parent company this Fall. They current have AP1852E-B-K9 and WLC5200 and they want to migrate to 9800-WL. I will have an instance of the 9800-WL stood up before cutover, but once the WAN is moved fr...
Hi, We are using jabber 11.6 ( for testing we have also 11.8, 12.0 ) in the CUCM Cluster ( 11.5 SU4) and users are facing weird issue while using the Jabber. Intermittently the first call of the day is experiencing the one way audio. In the logs a...
Hellocould you please share the solution for showing dropped packet from internet to inside lan ? i have FTD 4100 series managed by fmc I want to see output from cli or fmc related to nat transactions packet(dropped and passed) both.
Using Cisco Umbrella as firewall and attempting to play video that requires "jwplayer6" which is being blocked. Where do I search for the Clients IP Address in Umbrella so I can tell precisely what's going on? Thanks in advance.
Our WLCs currently have management access (HTTP/S, SSH, SNMP, etc.) restricted to certain IPs/subnets via an ACL in the router upstream. Is there a way to accomplish this on the controllers themselves, both for AireOS (version 8.10) and IOS (version ...
We have a 9800-CL Wireless Controller running 17.12.2. We just got a new CW9164I-ROW AP and its registered by the operational interfaces are down due to a regulatory domain error. Is there a way to change the regulatory domain for the access point?...
Our Customer is facing issue on their corporate SSID , We have capture debug and found below logs . Can anyone suggest what can be issue , currently WLC is on IOS 8.5.171.0 and access points connected AIR-CAP3702I-Z-K9.Debug logs apfMsConnTask_3: Apr...
Hi TeamSince CCP was retired if I am to implement Telephony on the ISR 4000 series is there a replacement or will i have to do all configuration via CLI? thanks
Hello Cisco Community,I've encountered what appears to be a bug in the DataCallbacks class implementation, specifically within the register method that is responsible for ensuring a data handler implements required methods. I would appreciate some gu...
