Warning message
Do 3905 need transcoding for g729r8
Mar 28th, 2014
Hi all,
i have the following problem:
3905 is registered on a CME-1 with codec preference g729r8 and then g711 u and a
CME-1 has a sip trunk to another CME-2 using the same codec voice class order
CME-2 has the same settings for calls to CME-1
SPA502 phone on CME-2 calls 3905 on CME-1
While ringing, i can see the codec is g729r8.
As soon as 3905 pickups, the call is dropped.
If i use, g711u, a or g729br8, calls are established OK.
Any ideas why the 3905 does not negitiates g729r8?
Anthony
manpreet singh Fri, 03/28/2014 - 08:33
Please attach the Show run of the router and also collect the following debugs for a test calls
Debug voice ccapi inout
debug h245 asn1
