03-28-2014 07:36 AM - edited 03-17-2019 04:03 PM
I am having complete failure when trying to get any version of Jabber in 9.2, 9.6, or 9.7 to pass custom install values whether with a MST'd MSI or via a command line argumemt in a batchfile. It's beyond maddening, as I'm folowing the guides to the letter. As a task, this isn't difficult. And from the installer log, you can see it's passing the parameters. I did notice that it didn't build a bootstrap file though.
I've used both Orca and Insted with the same results. A Google search showed I wassn't the only one.
roperty(S): USERNAME = admin
Property(S): FORGOT_PASSWORD_URL = <URL to organizations change password site>
Property(S): SSO_ORG_DOMAIN = <SSO Org Domain>
Property(S): TYPE = CUP
Property(S): ADDRESS = flmvpggresence1
Property(S): TFTP_FILE_NAME = <TFTP file name>
Property(S): LANGUAGE = <The language code e.g. 1033>
Property(S): DOMAIN = whyme.local
Property(S): CLEAR = 1
Property(S): PRODUCT_MODE = <Default or Phone_Mode>
Property(S): TFTP = <TFTP server address>
Property(S): CTI = <CTI server address>
Property(S): CCMCIP = <CCMCIP server address>
Property(S): LOGIN_RESOURCE = <Client instance logins>
03-28-2014 10:13 AM
04-11-2014 12:09 PM
It turns out if you delete the rows from the transform that you ultimately are not using, the transform then works properly.
