CUCM Announce Dialed Number
Answered Question
Mar 28th, 2014
Is there a function in CUCM 9.1 that will announced Dialed number back to user to verify if that is the number they want to call. I am thinking for "911" called number. If by mistake a user dials "911" they would know to hang up before the call goes through.
Thank you,
Correct Answer by Jaime Valencia about 3 years 4 months ago
You can always simply route to CUC, and use caller input so they verify it they actually wanted to call 911 or not.
Correct Answer by Anthony Holloway about 3 years 4 months ago
Yes, it's called External Call Control Profiles and this feature has ben available since CUCM 8.0.
It leverages the Annunciator service to play an announcment to the caller.  Be warned, it's no simple admin task and requires access to developer.cisco.com to implement.  Perhaps Cisco will bring this simple functionality into a simple check box one day, but for now, it's a little more complicated.
Overall Rating: 5 (2 ratings)
Ayodeji Okanlawon Fri, 03/28/2014 - 09:16
  • Cisco Designated VIP,
    2017 IP Telephony
No, there is no such feature native to any CUCM version.
Correct Answer
Anthony Holloway Fri, 03/28/2014 - 11:21
  • Purple, 4500 points or more
Correct Answer
Jaime Valencia Fri, 03/28/2014 - 11:36
  • Cisco Employee,
  • Hall of Fame,
    2011
