Warning message
WLC-4402 boot failure
Answered Question
Mar 30th, 2014
I had unplugged the controller to move it, when it was plugged back in and started it back up it comes up with the following output.
Bootloader 4.2.61.0 (Oct 24 2007 - 19:31:59)
Motorola PowerPC ProcessorID=00000000 Rev. PVR=80200020
        CPU: 833 MHz
        CCB: 333 MHz
        DDR: 166 MHz
        LBC: 41 MHz
L1 D-cache 32KB, L1 I-cache 32KB enabled.
I2C:   ready
DTT:   1 is 24 C
DRAM:  DDR module detected, total size:512MB.
512 MB
8540 in PCI Host Mode.
8540 is the PCI Arbiter.
Memory Test PASS
FLASH:
  Flash Bank 0: portsize = 2, size = 8 MB in 142 Sectors
 8 MB
L2 cache enabled: 256KB
Card Id: 1540
Card Revision Id: 1
Card CPU Id: 1287
Number of MAC Addresses: 32
Number of Slots Supported: 4
Serial Number: FOC1148F086
Unknown command Id: 0xa5
Unknown command Id: 0xa4
Unknown command Id: 0xa3
Manufacturers ID: 30464
Board Maintenance Level: 00
Number of supported APs: 50
In:    serial
Out:   serial
Err:   serial
                     .o88b. d888888b .d8888.  .o88b.  .d88b.
                     d8P  Y8   `88'   88'  YP d8P  Y8 .8P  Y8.
                     8P         88    `8bo.   8P      88    88
                     8b         88      `Y8b. 8b      88    88
                     Y8b  d8   .88.   db   8D Y8b  d8 `8b  d8'
                      `Y88P' Y888888P `8888Y'  `Y88P'  `Y88P'
                    Model AIR-WLC4402-50-K9   S/N: FOC1148F086
Net:
 PHY DEVICE  : Found Intel LXT971A PHY at 0x01
FEC ETHERNET
IDE:   Bus 0: OK
  Device 0: Model: STI Flash 8.0.0 Firm: 01/17/07 Ser#: STI1M9F407290174826
            Type: Removable Hard Disk
            Capacity: 245.0 MB = 0.2 GB (501760 x 512)
  Device 1: not available
Booting Primary Image...
Press <ESC> now for additional boot options...
bzImage Image Integrity Check Failed(Bad Header Checksum).Hanging
I also tried to select any of the other boot options but not matter which option I choose it comes up with
I am assuming that the CF card has gotten corrupt, I put the card in a reader into a PC and it does show the partitions with the bzimage and initrd files.
Anyway to get the boot image files and move them a new CF card? I havent had this controller very long (used product, for lab use) would hate to have to fork out the cash for another one if theres's a way to recover it.
UPDATE: I was able to get the controller going again, replaced the onboard RAM module. The part numbers that were on the module showed as a 512MB PC2700S DDR 333MHz SODIMM. Found some used memory matching those specs and it booted right away. Its been working great for two weeks now. Looks like the known memory issue was the problem after all.
Correct Answer by patoberli about 3 years 4 months ago
Overall Rating: 5 (2 ratings)
m.kieffer Wed, 04/02/2014 - 17:08
Dont think that bug code is revelent in this case as its for the Cisco 5500 Series Wireless Controllers
and the software releases are not even close to what this controller was running.
error code is differnet as well the bug lists:
bzImage Image Integrity Check Failed(Bad Magic Number). Hanging
I am getting
I am assusing that TAC wont even talk to me since there is no SmartNET on this.
Thanks for the reply though
Related Content
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
