Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1927712members
1240694discussions
Community Activity
Static Routes on FTD 2130 using CLI
Has anyone Created statoc route on the FTD sensor via the CLI?Mine looks like it goes throught bu when i FDM into it, i do not see them. Any Advice will be appreciated.Thanks.
Knassi by Level 1
  • 53 Views
  • 3 replies
redundancy in core layer
hi guys . i have a network with below topology. In the core layer, I want to have redundancy, which means that if the main core switch of my network has a problem, the backup switch will automatically enter the circuit. What method is there?
chpmotry by Level 1
  • 191 Views
  • 16 replies
Setting a GRE tunnels between a NAT to a public IP.
Hi everyone.. i have been looking through multiple posts on the forum for similar cases but have not found the answer Im looking for.. I've been primarily using this thread for guidance. https://community.cisco.com/t5/networking-knowledge-base/settin...
jonmo2578 by Level 1
  • 103 Views
  • 3 replies
cisco lock
hey.i need to know how can i lock my username for a time more than a month from my access not managerial access?
L2VPN Over GRE
Hi I'm trying to extended a L2 segment using MPLS L2vpn over GRE. I am able to establish the tunnel and get ospf and mpls adjacency also the xconnect between the peer is up but my 2 test pc cant reach each other. This is my PE3 config.interface Gigab...
Resolved! New Blog: Changes to the Meetings Server API and SDKs
New Blog: Changes to the Meetings Server API and SDKS, as they relate to the Webex Suite Meeting Platform. Join Raffaele Lagana for an overview of the steps required to migrate your current Webex SDKs workflows to the new Webex Meeting Suite Platform...
kaabadi by Cisco Employee
  • 39 Views
  • 1 replies
ASR1001-X Thruput only 750 meg Interfaces10G both sides -Circuit 10G
We have a Cisco ASR1001-X and it can only pass 750 megs of traffic thru it on a 10 Gig circuit. I looked at licensing levels and they seem correct. Anyone have any ideas of what I can look at? Both Lan and Wan interfaces are 10 gig and Wan is using S...
jroy777 by Level 1
  • 124 Views
  • 6 replies
Personal Account on CX?
Hello, I would like to know if there will be no discrepancy if I use a personal account on teh CX Cloud but for a company use? thank you.
BGP-LS ; how is BGP-LS data processed in BGP RIBS
Hello, I am working on collecting BGP-LS SAFI using BMP towards Cisco's opensource project Jalapeno. I have captured packets between RR and Jalapeno on each use case to observer where we see BGP-LS and where we DON'T see BGP-LS packets. few use cases...
Cisco 2960X and 9200L POE support for Paxton
Hi,We currently have a mix of Cisco switches from 2960s, 2960X and now the 9200L.  However we are having issues with our Paxton POE door controllers. The 2960s work with all of our Paxton ControllersThe 2960X up to hardware version 4 work with the Pa...
