Warning message
HSRP back Routing with single ASA
Mar 31st, 2014
Hi Cisco Guru
I am little expertise in Cicso & handling Cisco devices companywide from about 10 years. We are thinking to increase network device failover/Redundancy & in this part we have added a new Router 2911 in our network. During my failover configuration planning I am facing lot of issues with HSRP/VRRP. I have attached here my network diagram & the following services running on my devices –
Cisco Router 2901            : Running Private BGP for with my ISP, two link is there into two POP.
ASA5520                           : Running in routed mode with NAT, IPSec VPN & Site-to-Site VPN.
Cisco Router 2911            : Running EIGRP, All VLAN routing & ACL.
4500X                                 : Using as Distribution Switch with VSS.
Can you please advise me how I can do failover of my 2911 Router. Specially I am facing issue with back routing from firewall since I have only ONE.
Thanks in advance
Regard
Mannan
CCNA
