The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally. New Here? Click here to learn more and get started.
Cisco Community is an active and collaborative place to learn more about our products and ask questions of peers and Cisco experts! Check out some of the most popular conversations happening right now!
hello alli was searching on how to integrate PCCE with C4C CRM system, and there were no documentation regarding this matter.i need to know what should be done from the PCCE side in order to route the calls to the CRM system and show the call informa...
*+1-945-468-9977 } How Do I Change My 헙light on Air CanadaTitle: How Do I Change My 헙헹헶헴헵혁 on 헔헶헿 헖헮헻헮헱헮: A Comprehensive GuideIn the dynamic world of travel, plans can change at the drop of a hat. Whether it's a sudden change in schedule, an unexpec...
Passengers can call 헞혂현헮헶혁 헔헶헿현헮혆혀 by dialing the 24x7 헞혂현헮헶혁 헔헶헿현헮혆혀- + ퟭ-ퟴퟱퟱ-ퟳퟯퟴ-ퟰퟰퟴퟭ (Live agent) and get a quick answer on the call. You can get 24-hour immediate assistance on your query. How do I talk to a 헞혂현헮헶혁 헔헶헿현헮혆혀 representative fast? 헞혂...
I am trying to get my head around this to make sure i've understood this correctly. Hopefully someone will be able to clarify it for me. 1. As per the below image, I can see that Balanced and security is enabled as a default for NAP in the default...
I am trying to create a service app for CDETS and have submitted it for Admin Authorization, but have gotten no response. WebEx developer support team was not able to find out who to contact about it. Does anyone know how I can get the authorizatio...
Hi all,We had implemented Teams direct routing setup with a pair of CUBEs in High Availability mode (about a year ago) and the certificate (sbc.mydomain.com) is about to expire. I would like some help on the steps required to renew the certificate, b...
Using the Api for Authenticated users list : https://{ISE-MNT}/admin/API/mnt/Session/AuthList/{START_TIME}/{END_TIME}I am able to fetch data of active sessions that are connected throughout the time period of 30 days whereas I also want to fetch d...
Hello, since a few weeks, we are notice a lot of timeouts in our network. We figured out that there are unplanned reboots in our stack. This is what the stack is logging: We are using the stack in a ring-topology in hybrid-mode with the firmware 2.5....
We have an export repository configured for our Radius/Tacacs Data under System/Maintenance/Operational Data Purging which leads ISE to write many small .tar.gpg files on our repository server.I would now like to run reports from this data but I am n...
Hi Team,I have created webhook to integrate it with webex bot, Bot is responding properly when I ping it, but if someone from the team ping the bot its not responding. Can someone help me out on this,I am not sure where I am going wrong
HiI'm trying a very simple LAN Automation test where I have one Border manually configured and discovered which I am then going to use as a seed device for my second Border. When I start the LAN automation process the second Border upgraded to my Go...
Hi,after a upgrade from xe 3.11.07 to 3.11.09 we cannot open a ssh session to our 4510+R Switch. Before the upgrade everything works fine. The error message in the log is:%SSH-3-BAD_PACK_LEN: Bad packet lenghthWe zeroised the rsa key and generate i...
The LED light of 3802 AP is off after registered with 9800 WLC . But the 3802 access point is still working perfectly in providing the wireless connection to the end device . We have factory-reset the AP and issue remain the same after the AP regist...
