Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1926251members
1237854discussions
Community Activity
Cannot add FTD to FMC after deleting it from FMC
Hi,FTD was added and to FMC and while configuring HA in FMC, deleted FTD from FMC.While trying to add again to same FMC, both primary and secondary FTD not getting registered in FMC.Could you please help on getting the FTD registered with FMC.
riyas_tvm by Level 1
  • 0 Views
  • 0 replies
Hi Is there any document that shows that WLC 9800-40 support wifi-6 and 6G band! I cant find that document
Moudar by VIP
  • 3 Views
  • 1 replies
Secure Client ISE 3.2 Posture failure
I have just started using Secure Client Posture on my windows workstations.  All but 2 work fine.  The two are using the IP of the ISE instead of the FQDN.  All systems have the same ISEPostureCFG.xml files on them. If I disable the network connectio...
Cisco Secure Client XML overwrite issue
Hello, any help appreciated.I am having issues when trying to assign a different group policy to a user where the group policy contains a different client profile (XML) to the one used to connect in the first instance. This is what I am trying to do....
Router Modem and CRC Relationship
Hi,We are finding that some router models are more susceptible to CRC increase/snr decrease than others and tend to lose sync more easily especially when it comes down to sudden spikes in crc indicative of REIN/SHINE issues. Im trying to determine wh...
Obi-WWAN by Level 1
  • 7 Views
  • 0 replies
permit ip ifc outside any any
We have FMC and FTD , In FMC we configured Blocked traffic ACCESS POLICY , but while checking in FTD(CLI) one more ACL( Ifc Outside any any allow) showing with same rule-id 26844160.   any ideas how to find this ACL in FMCACL in FTD ========access-li...
Warranty headache
I have a piece of equipment that support acknowledges to be covered under warranty, but they are refusing to help, as it is allegedly not associated with my CCO ID (even though I deliberately registered it and see it listed). Does anybody have any su...
haramny by Level 1
  • 33 Views
  • 1 replies
new user on Cisco Firepower 1120 unable to https
Team,We have a new Cisco Firepower 1120 just configured with basic configuration.After the admin user I added another user with the "configure user add" command.This new user can SSH to the device but cannot SSL.Further, I want to ensure that this ne...
DMVPN issue with 800 series routers
I have a DMVPN network with 4331 hub routers. Our HQ in Memphis has a hub on AT&T, and another on Lumen. Our New York hub is also a Lumen connection. All are 500Mb up/down. We have about 35 spokes around the US that peer to all 3 routers. BGP is the ...
Recommendation Software ISE
Hi EveryoneOur client for ISE software still uses version 2.6 with pach 10,We will upgrade the software to 3.1 with patch 8, please provide a recommendation link from CiscoI'm afraid that if I downloaded it wrong it would have fatal consequencesThank...
