Warning message
VPN Client 401 error
Apr 2nd, 2014
I am running a 881-w in the office. We have a couple of outside sales people that need access from time to time.
I installed and tried connecting to our router with Cisco VPN Client.
I think I may have configured something in the EZVPN settings wrong.
Any help would be appreciated, I am pulling what little hair I have left out.
Here is the error I get from VPN client.
Initializing the connection...
Contacting the security gateway at 24.103.151.2...
Authenticating user...
Negotiating security policies...
Secure VPN Connection terminated locally by the Client.
Reason 401: An unrecognized error occurred while establishing the VPN connection.
 Here is my config file
Using 5484 out of 262136 bytes
! Last configuration change at 19:50:57 UTC Sun Mar 23 2014 by admin
version 15.1
no service pad
hostname ashly
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
aaa new-model
aaa authentication login default local
aaa authentication login USER local
aaa authorization network GROUP local
aaa session-id common
memory-size iomem 10
crypto pki trustpoint TP-self-signed-2605410574
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-2605410574
 revocation-check none
 rsakeypair TP-self-signed-2605410574
crypto pki certificate chain TP-self-signed-2605410574
 certificate self-signed 01 nvram:IOS-Self-Sig#6.cer
ip source-route
ip dhcp excluded-address 10.10.10.1
ip cef
ip domain name yourdomain.com
ip name-server 24.92.226.11
ip name-server 24.92.226.12
no ipv6 cef
license udi pid CISCO881W-GN-A-K9 sn FTX134280PZ
username admin privilege 15 secret 5 ########################
username ashlyguy privilege 15 password 0 ########
username mike password 0 #######
no ip ftp passive
crypto ctcp port 10000
crypto isakmp policy 1
 encr aes
 authentication pre-share
 group 2
 lifetime 7200
crypto isakmp key Cisco address 0.0.0.0 0.0.0.0
crypto isakmp client configuration address-pool local EZVPN
crypto isakmp client configuration group EZVPN
 key #######
 dns 8.8.8.8
 wins 192.168.1.42
 pool EZVPN_POOL
 netmask 255.255.255.0
crypto isakmp profile EZVPN_PROFILE
   match identity group EZVPN
   client authentication list USER
   isakmp authorization list GROUP
   client configuration address respond
   virtual-template 1
crypto ipsec transform-set EZVPN_SET esp-aes esp-sha-hmac
crypto ipsec profile EZVPN_PROFILE
 set transform-set EZVPN_SET
 set isakmp-profile EZVPN_PROFILE
interface FastEthernet0
 spanning-tree portfast
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
 description $ES_WAN$$ETH-WAN$
 ip address 24.103.151.2 255.255.255.248
 ip nat outside
 ip virtual-reassembly
 duplex auto
 speed auto
interface Virtual-Template1 type tunnel
 ip unnumbered FastEthernet4
 tunnel mode ipsec ipv4
 tunnel path-mtu-discovery
 tunnel protection ipsec profile EZVPN_PROFILE
interface wlan-ap0
 description Service module interface to manage the embedded AP
 ip unnumbered Vlan1
 arp timeout 0
interface Wlan-GigabitEthernet0
 description Internal switch interface connecting to the embedded AP
interface Vlan1
 description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
 ip nat inside
 ip tcp adjust-mss 1452
ip local pool EZVPN 192.168.1.240 192.168.1.243
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list inside-nat-pool interface FastEthernet4 overload
ip route 0.0.0.0 0.0.0.0 24.103.151.1
ip access-list standard rtraccess
 permit 192.168.1.0 0.0.0.255
ip access-list extended inside-nat-pool
 permit ip 192.168.1.0 0.0.0.255 any
no cdp run
control-plane
banner exec ^C
^C
banner login ^C
^C
line con 0
 no modem enable
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
line vty 0 4
 access-class rtraccess in
 privilege level 15
 transport input ssh
 transport output telnet ssh
end
Federico Coto F... Wed, 04/02/2014 - 14:59
  • Green, 3000 points or more
Hi, probably there's something misconfigured, I will first check if the problem is this command that you have on the Router: crypto ctcp port 10000 That command is instructing the router to listen for the IPsec connection on TCP port 10000 By default the client won't use ESP over TCP, but instead will use UDP. So, change the client to use TCP port 10000 to connect, or remove the command from the router to allow the client to connect using UDP. If the problem persists, you can share the output from "debug cry isa" and "debug cry ipsec" from the router along with the logs from the client itself. Hope it helps.
