Warning message
Webmail Server
Apr 3rd, 2014
We have a Cisco ASA 5505 that works great but employees on the outside of the office using Microsoft exchange to get emails on their cell phones or laptops when they go to mail.xxxxxxxx.com it show up that the server is not there.
Any help would be great
ciscoasa(config)# show startup-config
: Saved
: Written by enable_15 at 10:39:46.869 CDT Thu Apr 3 2014
ASA Version 8.2(5)
hostname ciscoasa
domain-name zeavision.com
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0/0
 switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
 nameif inside
 security-level 100
interface Vlan2
 nameif outside
 security-level 0
 ip address 68.191.203.114 255.255.255.252
ftp mode passive
clock timezone CST -6
clock summer-time CDT recurring
dns server-group DefaultDNS
object-group service rdp tcp
 port-object eq telnet
object-group service rds tcp
object-group service sslvpn-http tcp
 port-object eq www
object-group service sslvpn-https tcp
 port-object eq https
access-list inside_access_in extended deny tcp any host 188.53.0.0 object-group
rdp
access-list inside_access_in extended permit tcp host 192.168.1.12 any
access-list inside_access_in extended permit tcp host 192.168.1.12 any eq smtp
access-list inside_access_in extended permit tcp host 192.168.1.12 any eq www
access-list inside_access_in extended permit tcp host 192.168.1.12 any eq https
access-list inside_access_in extended permit tcp host 192.168.1.12 any eq pptp
access-list inside_access_in extended permit tcp host 192.168.1.10 any eq ftp
access-list inside_access_in extended permit tcp host 192.168.1.12 any object-gr
oup rdp
access-list inside_access_in extended permit udp any any
access-list inside_access_in extended permit tcp any any
access-list inside_access_in extended permit ip any any
access-list inside_access_in extended permit tcp any any eq smtp
access-list outside_access_in extended permit udp any any eq dnsix
access-list outside_access_in extended permit tcp any any eq smtp
access-list outside_access_in extended permit tcp any any eq www
access-list outside_access_in extended permit udp any any eq ntp
access-list outside_access_in extended permit ip any any
access-list outside_access_in extended permit tcp any any object-group rds
access-list outside-to-inside extended permit tcp any host 68.191.203.114 eq htt
ps
access-list outside-to-inside extended permit tcp any host 68.191.203.114 eq smt
p
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-715-100.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
access-group inside_access_in in interface inside
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 68.191.203.113 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
aaa-server ZeaVision protocol radius
aaa-server ZeaVision (inside) host 68.191.203.114
 timeout 5
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.1.5-192.168.1.254 inside
dhcpd dns 24.217.0.5 24.217.201.67 interface inside
dhcpd lease 86400 interface inside
dhcpd domain zeavision.com interface inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics port
threat-detection statistics protocol
threat-detection statistics access-list
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 averag
e-rate 200
webvpn
 enable outside
tunnel-group ZeaVision type remote-access
tunnel-group ZeaVision general-attributes
 authentication-server-group ZeaVision
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
 class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:73c241cff44ed89bd356a0ae893279e5
ciscoasa(config)#
