Warning message
Cisco ASA DHCP Server and Relay agent
Answered Question
Apr 4th, 2014
Hi Guys,
Is it possible to allow DHCP Server on some of the interfaces/subinterfaces and DHCP relay agent on other subinterface on a Cisco ASA?
I have a Cisco ASA what is DHCP server for several vlans.
I need MAC address reservation on one. As ASA doesn't support this feature I decided to set on the my Cisco switch.
The switch is connected to the ASA (there is no DHCP server on this subinterface)
IP of the switch is on a different subinterface like MAC reservation (10.50.30.100 interface sun_devices).
When I wish to activate the DHCP relay agent I got the following error message:
asa01(config)#dhcprelay server 10.50.30.100 sun_devices
asa01(config)#dhcprelay setroute sun_admins
asa01(config)#dhcprelay timeout 60
asa01(config)# dhcprelay enable sun_admins
DHCPRA: can't enable DHCP Relay when DHCPD is running on any interface
       Use the 'no dhcpd enable <server_ifc>' command
       on any interface that has been enabled.
dhcprelay command failed
Many thanks!
Correct Answer by Ruben C about 3 years 4 months ago
optional you can push all DHCP scopes for the switch and apply the dhcp relay on firewall interfaces
Overall Rating: 5 (1 ratings)
Correct Answer
Ruben C Fri, 04/04/2014 - 04:06
  • Bronze, 100 points or more
  • Community Spotlight Award,
    Portuguese Best Publication, April 2017
Steve Block Fri, 04/04/2014 - 04:30
Yes, that's an option, but I want to keep other DHCP servers on the ASA.
Ruben C Fri, 04/04/2014 - 04:45
i guess you are running dhcp enable on the interface you are trying using relay. You need to delete first the scope/interface config regarding it. If it still not working check if for that version has caveats about it
Steve Block Fri, 04/04/2014 - 05:18
These are sub-interfaces of a physical interface.
ethernet 0/1.3 sun_devices
ethernet 0/1.123 sun_admins
ethernet 0/1.124 further vlans...
DHCP hasn't set to sun_devices and sun_admins, but enabled on the further VLANs.
Need I remove DHCP server from all sub-interfaces?
Ruben C Fri, 04/04/2014 - 06:44
remove the pool and DHCP associated that particular interface and apply the dhcprelay command and the dhcprelay server
Steve Block Fri, 04/11/2014 - 00:43
I tried this suggestion, but didn't work. I think, if there is a dhcp server on the ASA there is no way to DHCP Relay on it. Finally I moved all of the DHCPs to the layer 3 switch.
