04-04-2014 05:54 PM - edited 03-07-2019 07:00 PM
Please I want to find out if it is possible to use all uplinks ports on the 8 port Sup8-E modules configured as a redundant pair on a single 4510R+E chassis?
I noticed that only 4 ports are active on each sup8-E modules (making it a total of 8 ports) but I will like to use all 16 uplink ports on both modules.
The chassis is licensed for entservices and the current ios is Cisco IOS XE Release 3.3.0XO(15.1(1)XO).
Thanks in advance for your help.
Josh.
04-04-2014 06:14 PM
When you have 2 sups in the chassis, you can only have 4 ports active per sup.
04-23-2014 10:42 AM
Yes.. 4 ports per sup. If you only had one sup then you can have 8 ports active
04-30-2014 01:54 AM
you can 4x 1/10Giga ports per SUP when you have 2 SUPs in a 4510R+E...but it seems that if you have a 4507R+E you can have only 2x 1/10 Giga ports per SUP
See Table High-Availability, Uplink and Wireless Options for Supervisor Engine 8-E in http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-4500-series-switches/data_sheet_c78-728191.html
It will be possible in future to not have this limitation?!?
BR
Omar
03-06-2018 06:24 AM
Hello JIAQI,
4500E Supervisor Engine 8-E Uplinks 1GE/10GE Mode
You can refer the link below .
