Warning message
Hsrp on two cat3750 routed port facing Nexus router with HSRP
Apr 5th, 2014
Hi there,
I want to have HSRP configured in my two cat 3750 routed port, the routed ports are connected to two Nexus router also running HSRP.
Is it possible with this kind of set up?
I tried configuring HSRP on each router port of the L3 switch, but when i tried running "sh standby" or "sh standby brief" both are in "Active State". what connection should  I have between switches to make HSRP work on routed ports.
server (vlan 10) -----------------Switch 1 and switch 2
Server (vlan 20)------------------Switch 1 and switch 2                                         Switch 1(hsrp)----------------Nexus1 (hsrp)
        Switch 2(hsrp)----------------Nexus2 (hsrp)
Server (vlan 30)-----------------Switch 1 and switch 2
My goal is to use 3750 as layer 2 for the servers and layer 3 when uplink going to router with hsrp on switches facing hsrp on nexus.
IP's
x.x.x.0/29 -----network
x.x.x.1 -------VIP nexus
x.x.x.2 -------Nexus 1 ip
x.x.x.3 -------Nexus 2 ip
x.x.x.4 -------Switch 3750 VIP
x.x.x.2 -------Switch 1 ip
x.x.x.3 -------Switch 2 ip
x.x.x.5 ----broadcast address
Note: I only handle the configuration for the two 3750 switches.
Related Content
