EDRRM AQ and AQI
sreejith_r
Hi ;
     Whats the difference between EDRRM AQ and AQI. If we are setting the  sensitivity on the EDRRM to high the value will be 60. Whats the value we are configuring the AQI in the clear air tab. is it only for traps.
If i want to change the AP  channel  based on the AQI value where i should set .
I should change the EDRRM to high or change the AQI value in the clean air.
Thanks & Regards
Sreejith R
Hi Sreejith,
Yes, that should be fine.
Pls mark this thread "answered" if this clarify your query.
Rasika
Hi Sreejith,
Here is some reference post on this topic
http://mrncciew.com/2013/05/02/event-driven-rrm/
If you change the sensitivity to "high", then it is good idea to change AQI alarm threshold to 60 as well. Yes AQI threshold is only for traps.
You need to enable Clean Air & change EDRRM sensitivity (High-60, Medium-50, Low-35) in order to change  AP channel based on AQI value of 60,50 or 35
Rasika
**** Pls rate all useful responses ****
Thanks Rasika
So it means if we want to trigger the channel change based on AQI , its not necessary to change the AQI threshold
Only change the EDRRM to low/medium/high and enable clean air.
Please confirm
Hi Sreejith,
Rasika
