Warning message
dot1x auth commands on the slave switch of the stack not accepted
Apr 6th, 2014
          we are not able to enter the authentication commands on ports of the  second switch of the same stack, the ports on the 1st switch accept the commands :
KPC-C3750X-FL2-SW(config)#int gi 2/0/26
KPC-C3750X-FL2-SW(config-if)#ip access-group ACL-ALLOW in
KPC-C3750X-FL2-SW(config-if)#authentication host-mode multi-auth
% Invalid input detected at '^' marker.
KPC-C3750X-FL2-SW(config-if)#authentication open
KPC-C3750X-FL2-SW(config-if)#authentication order dot1x mab
Here is the show version from the stack
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 15.0(2)SE1, RELEASE SOFTWARE (fc1)
Technical Support: http://www.cisco.com/techsupport
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Fri 04-Jan-13 01:38 by prod_rel_team
ROM: Bootstrap program is C3750E boot loader
BOOTLDR: C3750E Boot Loader (C3750X-HBOOT-M) Version 12.2(53r)SE2, RELEASE SOFTWARE (fc1)
KPC-C3750X-FL2-SW uptime is 49 weeks, 3 days, 1 hour, 55 minutes
System restarted at 08:20:56 UTC Thu Apr 25 2013
System image file is "flash:/c3750e-universalk9-mz.150-2.SE1/c3750e-universalk9-mz.150-2.SE1.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
License Level: ipservices
License Type: Permanent
Next reload license Level: ipservices
cisco WS-C3750X-48P (PowerPC405) processor (revision F0) with 262144K bytes of memory.
Processor board ID FDO1635R1Z5
Last reset from power-on
9 Virtual Ethernet interfaces
1 FastEthernet interface
104 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 6C:20:56:09:CE:80
Motherboard assembly number     : 73-12553-06
Motherboard serial number       : FDO16350VMM
Model revision number           : F0
Motherboard revision number     : A0
Model number                    : WS-C3750X-48PF-S
Daughterboard assembly number   : 800-32727-03
Daughterboard serial number     : FDO16350TD0
System serial number            : FDO1635R1Z5
Top Assembly Part Number        : 800-31324-03
Top Assembly Revision Number    : B0
Version ID                      : V03
CLEI Code Number                : COMJZ00ARC
Hardware Board Revision Number  : 0x04
Switch Ports Model              SW Version            SW Image
*    1 54    WS-C3750X-48P      15.0(2)SE1            C3750E-UNIVERSALK9-M
     2 54    WS-C3750X-48P      15.0(2)SE1            C3750E-UNIVERSALK9-M
Switch 02
Switch Uptime                   : 49 weeks, 3 days, 1 hour, 22 minutes
Base ethernet MAC Address       : 6C:20:56:0C:33:80
Motherboard serial number       : FDO16350VDD
Daughterboard serial number     : FDO16350FHP
System serial number            : FDO1635X0LU
Top assembly part number        : 800-31324-03
Top assembly revision number    : B0
Version ID                      : V03
License Level                   : ipservices
License Type                    : Permanent
Next reboot licensing Level     : ipservices
Configuration register is 0xF
