HeartBleed SSL Bug - Cisco WLC´s a concern?
The Tops of our company came to us this morning and where all panic like:
http://heartbleed.com/
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-0160
Does anybody know if and what WLC Versions are a problem?
Thanks alot for your help!
12 Replies 12
MJonkers
What about cisco anyconnect? http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-0160
yeah, ALL cisco products for that matter - but at the moment I´m just responsible for the WLC´s :D (As they have "external" access because of the Guest users..)
Products Confirmed Not Vulnerable
The following Cisco products have been analyzed and are not affected by this vulnerability:
  • Cisco Adaptive Security Appliance (ASA) Software
  • Cisco ACE Application Control Engine
  • Cisco AnyConnect Secure Mobility Client for desktop platforms
  • Cisco AnyConnect Secure Mobility Client for Android
  • Cisco CSS 11500 Series Content Services Switches
MJonkers
See also http://www.kb.cert.org/vuls/id/720951 Cisco not yet reported.
bikejunkie
It would be good to know the breakdown of which products, if any are exposed.  We are looking specifically for Ironport Email Security Appliances and the email encryption appliance IEA devices.
Thanks!
http://tools.cisco.com/security/center/content/CiscoSecurityAdvisory/cisco-sa-20140409-heartbleed
mike.b.simpson
Seems that ASA are affected according to some test exploit site.
gwes
Vulnerable Products
The following Cisco products are affected by this vulnerability:
  • Cisco AnyConnect Secure Mobility Client for iOS
  • Cisco Desktop Collaboration Experience DX650
  • Cisco Unified 7900, 8900, 9900 series IP Phones
  • Cisco TelePresence Video Communication Server (VCS)
Does anyone know specifically what versions of the AnyConnect Client for iOS are vulnerable?
joshhunter
Level 4
Level 4
Hey, So according to the Cisco Security Advisory the WLC is listed as non vulnerable - So the WLC HTTPs WebGUI cert does not internally use OpenSSL or at least a vulnerable version.
What about those who are using a Captive Portal for Guest Wireless?
Many people use OpenSSL to convert 3rd Party certificates for the Portal as per the Cisco guides?
I have the answer to my question:
Please refer to the following link which mentioned that we can’t use any other versions than openssl 0.9.8, since the controller will not accept the certificate, please check the following links which mentioned that:
WLC HeartBleed 0.98 Required
http://www.cisco.com/c/en/us/support/docs/wireless/4400-series-wireless-lan-controllers/109597-csr-chained-certificates-wlc-00.html#conf
https://supportforums.cisco.com/document/102151/certificate-signing-requests-wlc-open-ssl
That's no longer the case.  OpenSSL 1.0 is supported from WLC 7.5.102 onwards.
This means if you have 7.6.X or above you should be OK to use OpenSSL 1.0 .  I successfully used 1.0.1g on a very up to date Gentoo Linux box only a week ago to convert, chain and upload a new wildcard certificate to my WLC.
See:  https://tools.cisco.com/bugsearch/bug/CSCti65315 for further information about this bug.
