04-08-2014 03:30 AM
Though it is easy way to install cpo using GUI.
my need is to install through cmd or script
can any one pls help...
Thanks in Advance
Solved! Go to Solution.
04-10-2014 02:10 PM
Shaun is correct. The silent install is not supported at this time, and is planned for a future version.
04-08-2014 09:31 AM
It is not supported at this time. I believe it will be around in 3.1... but that's out in the future. Von or Svetlana might be able to give more insight.
CPO install is pretty quick, are you trying to do mass installs or something?
04-10-2014 02:10 PM
11-20-2015 02:48 AM
This is both ironic, and sad.
11-20-2015 03:47 AM
Do not get this comment... what is it for?
This was posted a long time ago. CPO now supports CLI based and silent installs. See the install/user guide for more information. Latest version of CPO is now 3.2
11-20-2015 03:53 AM
Hi Christopher,
Then I'm confused! Am I missing something? - the docs here don't appear to have anything regarding it...
http://www.cisco.com/c/dam/en/us/td/docs/net_mgmt/datacenter_mgmt/Process_Orchestrator/3-2/Install_Guide/CiscoProcessOrchestratorInstallationGuide_3_2.pdf
(i'm searching it for "silent" and "cli" but nothing there)
If you can point me to a page that would be great.
Cheers,
David
11-20-2015 07:27 AM
Hey David,
I did not see much either so I have sent in a request to dev/doc to get this worked on. I'm not actually on the support team anymore so sometimes I am behind on that stuff... but I still work with them, so they will get it out I think.
In the meantime I wrote a blog on using the silent installer with 3.2 and recorded myself doing a silent install from beginning to end.
Enjoy!
https://supportforums.cisco.com/blog/12710681/pondering-automation-silence-golden
